Hello. I bought a beovision mx 4002, but I'm new to crt tvs so I have a couple questions.
1. Do the same geometry settings look different between different units of the same model?
2. Where can I find a list, which details every setting in the service menu?
3. Does anybody have some good geometry settings to share? I use the tv for emulation and want ntsc aspect ratios to fit on the screen.
4. I have heard about enabling deinterlacing to turn 480i into 240p by pressing shift 7 in menu, but it doesn't seem to do anything at all. What's up with that?
5. Are the 3 light beams colored when they leave the gun or do they get colored when they go through the shadow mask?
