Beovox 6210 - repair/restore
Jesper
Aars
Posts 19
Jesper Posted: Mon, Feb 22 2021 12:34 PM
Hi ;-)
To make a long story short(er), I went looking for a pair of Beovox 901 to match an old Beomaster 901 heirloom.
I ended up with a great little pair of 901's, but during my search I found a completely brused and abused pair of Beovox 3000 (6210, I think) and - against my better judgement - I fell head over heals in love with them!
They will need a LOT of tlc, but all drivers seem to be working, as best I can tell - except for the one woofer. It had been replaced with an unoriginal woofer, but I managed to get a hold of the original one. And defective it was, no doubt about it.
When pushing the cone down lightly, it gets stuck. Also I can't get an Ohm reading, why I suspect the coil to be broken in one form or another.
There you have it - this is my starting point - and I have a very clear vision in my mind of a very, very steep hill ;-)
I have absolutely NO idea if the woofer can be repared or if a replacement even exists?
I would very much appreciate any help with the woofer issue, as it is kind of a deal breaker to the entire project - no woofer, no point in taking it any further.
Regards,
Jesper...
Peter
Earsdon
Posts 11,991
Peter replied on Wed, Feb 24 2021 10:27 PM
I doubt you will find a new old stock but it could be repairable - I have used a firm called Wilmslow audio in the past to repair some not quite so old woofers and they seem very good. In the UK though but I am sure there will be something similar where you are.
Peter
Jesper
Aars
Posts 19
Jesper replied on Wed, Feb 24 2021 10:39 PM
No, I'm becoming painfully aware of the challange, but at this point the investment is just around 20 euros including gas.
Dillen told me stay patient - a solution will reveil itself at some point (I hope!) ;-)
Jesper...
Page 1 of 1 (3 items) | RSS
