I am working on an old Beolab 6000 right now too. I bought them on eBay and somebody has changed all 4 woofers against new ones from B&O. But he forgot all dampers and I think he didn't adjust the voltage for the speakers. I would like to check this and adjust this.
Now I have borrowed a signal generator to do this, but I am a little bit lost of using it. Maybe somebody can help me.
The service manual told me to use a voltage of 100mV and 10kHz for the tweeter and 10kHz for the woofers.
The signal generated can produce 100mVpp (peak to peak) or 100 mVrms. What should I use?
The RMS version.
Thank you. That was what I thought :-)
