Connection Between BeoLab Transmitter 1, BeoSound Essence, Beolab 18 and Beolab19
This post has 11 Replies | 2 Followers
13valdi
Posts 3
13valdi Posted: Wed, Jul 29 2015 9:31 PM
Good Afternoon,
I have one Beolab transmitter 1 (wireless), one BeoSound Essence, two Beolab 18 and one Beolab 19.
You could help me make this connection?
I am not sure how this connection should properly
If you could help me, I would appreciate it very much
Without further ado, and thanking you for your help.
LV
elephant
AU
Posts 8,219
elephant replied on Wed, Jul 29 2015 11:32 PM
I think you will get multiple answers, and mine is theoretical as I do not yet own an Essence.
Firstly, you did not list that you had a BeoLab Receiver - I expect that you do - but just checking :-)
DOH am I an idiot or what ?
Of course the 18s and 19 are wireless so no receiver needed
now editing my responses
Here is an initial simple wiring setup chart -- the extrapolation from this depends on your desired positioning of the sub woofer
BeoNut since '75
elephant
AU
Posts 8,219
from B&O ...
BeoNut since '75
elephant
AU
Posts 8,219
elephant replied on Wed, Jul 29 2015 11:45 PM
The challenge I see for you having just read the Transmitter, Receiver, and Essence manuals (very quickly as a refresh) is that the handling of the sub-woofer is tricky ....
There is a switch on the Transmitter to indicate whether the PL1 port is an input of a stereo+subwoofer signal, or simple stereo with PL2 (in your case) carrying the subwoofer.
However the Essence does not have a separate subwoofer output port.
So I believe you will need a 2xRJ to 1xRJ combiner cable to go from the Essence to the Transmitter, and that you will need to set the Transmitter subwoofer switch to 2.1
(Edited to cover the fact the speakers are wireless)
BeoNut since '75
elephant
AU
Posts 8,219
elephant replied on Wed, Jul 29 2015 11:49 PM
Deleted as the speakers are WISA wireless
BeoNut since '75
elephant
AU
Posts 8,219
elephant replied on Thu, Jul 30 2015 12:29 AM
Then set each of the speakers to WL for wireless rather than L or R and then in the wireless setup process you select which role they play
BeoNut since '75
Sibbi
Posts 87
Sibbi replied on Thu, Jul 30 2015 1:04 PM
One Ethernet cable between essence and transmitter 1.  its fairly easy to set up following the manual.  I have essence, transmitter 1 and beolab 17s. Like the sound.  But really don't like to operate the essence.  Good luck with your setup.
elephant
AU
Posts 8,219
elephant replied on Thu, Jul 30 2015 6:56 PM
Sibbi:
So each RJ port on the Essence is outputting R+L stereo signal ?
In which case, yes a straight through cable should suffice
BeoNut since '75
13valdi
Posts 3
13valdi replied on Fri, Aug 7 2015 6:23 PM
Thank you very much.
you help me a lot (:
eltelmo
Posts 2
eltelmo replied on Thu, Mar 18 2021 5:09 PM
can you help me?
how I connect transmitter to Essence? all the best
Stan
Chicago-area USA
Posts 869
Stan replied on Thu, Mar 18 2021 5:28 PM
You need an RJ45 powerlink cable to run from one of the PL sockets of the Essence to a PL input on the transmitter.  I believe a shielded Cat6 ethernet cable will also work - again, one end goes in an Essence PL socket, and the other to a PL socket on the transmitter.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Thu, Mar 18 2021 5:33 PM
eltelmo:
It should be:
Essence Speakers PL1  --> Transmitter PL1 using an Ethernet cable Cat 6 or Cat 7.
Transmitter B&O Input Switch = Yes
Page 1 of 1 (12 items) | RSS
