Hi.
I connect my MCL2P amplifier with a fully wired powerlink cable, and it turns on when i connect the cable. But it won`t turn off when i power off my Beosound 5. I have 2 Beolab 8000, connected as well, and they tuns on and off, following the beosound. Do i have to chenge the pinout on the powerlink cables? Any help is appreciated!
I am not totally sure but I think you may need to connect PL pins 1 and 4 for this to work.
Have a look at Stefan's last post on this thread: https://archivedforum2.beoworld.org/forums/p/4407/39429.aspx#39429
I think you got the answer there. The turn on pins are different on old and new stuff.
I will look in to it.
Thanks for your help.! :-)
