New Beosound Core software ver. 2.0.47943
This post has 4 Replies | 2 Followers
pig30n
Posts 35
pig30n Posted: Tue, Jan 11 2022 3:57 PM
This just popped today in the app. Anybody installed it ?
Is there a change log somewhere ?
Cheers.
swestland
Netherlands
Posts 73
swestland replied on Tue, Jan 11 2022 6:59 PM
I installed it immediately my shapes core as I’m having playback issues. Can’t find any change log.
- Beovision Eclipse 55 Mk2 - Beolab 19 - Beosound Shape - Oppo UDP-203
65535
South East England
Posts 26
65535 replied on Tue, Jan 11 2022 7:08 PM
Is there ever a published changelog with B&O builds? Serious question
Beovision Horizon 48, Beolab 17, Beolab 19, Core, Beosound Stage w/ Sony, BeoSystem 4, Beoplay M3
pig30n
Posts 35
pig30n replied on Tue, Jan 11 2022 8:07 PM
I’ve updated mine and my first impression is that Spotify Connect works a little smoother. Hi-speed surfing a track in the app seems faster than in 1.12. Although, previous versions, 1.10 and 1.11, were better.
I saw no new sound options added in the App. I like the “purist”, “hi-fi”,  feel of it:  just Bass and Treble :).
I haven’t had any playback issues tho.
If you are having playback issues, I suggest trying to wire your Core directly to your router using a CAT 6 cable that has metallic RJ45 plugs. See if it’s any different. If you can’t wire it, make sure you have good wifi signal to your Core. Go to “Setup Overview”->Your Beosound Core Name, and the wifi signal should be greater than -50dBm (eg -40dBm is better than -50dBm).
I also have a Beosound Stage, over WiFi, that was dropping multiroom playback together with the Core because it had -55dBm wifi signal. After a few re-arrangement, I managed to get the signal around -44dBm and now there’s no more multiroom playback drops from the Stage.
henrik
Sweden
Posts 458
henrik replied on Sat, Jan 15 2022 8:08 PM
The only difference I've seen it that the Core now has a balance setting! ...or was that added in a previous update?
What I'm hoping for: less problems when having several access points with the same SSID. I currently have my Core cabled, but I'll give wi-fi a go again soon.
Page 1 of 1 (5 items) | RSS
