Hi!
We gave the Avant 55 a new location in the house the other day (heavy and maaany cables to disconnect and reconnect). Today I noticed the speakers won´t move. They are in full active position and sounds just like they should, but when the TV is turned off and rotates back on the floor stand the speakers stay out in position.
Anyone having a clue what happended, and what to do to get the magic back?
On my parents TV, when it does this I put them in my self.
So when you turn off the Avant, take your hands and press on both sides of the speaker, you do not need to press very hard.
Then is goes in and up, and it works again.
I hope it helps in your case to.
Emil Jensen: On my parents TV, when it does this I put them in my self. So when you turn off the Avant, take your hands and press on both sides of the speaker, you do not need to press very hard. Then is goes in and up, and it works again. I hope it helps in your case to.
Nope, it didn´t work. They are stuck and I pressed rather hard without any luck.
Have you tried, disconnecting the main electrical supply, waiting for a minute or two, then reconnecting mains and then turning the tv on with the Beoremote? This has resolved the problem for me a couple of times.
Hi Daniel,
you moved the TV in the house with the speakers in "stay out position" ?
Greetings
Siggi
Gary: Have you tried, disconnecting the main electrical supply, waiting for a minute or two, then reconnecting mains and then turning the tv on with the Beoremote? This has resolved the problem for me a couple of times.
I tried to disconnect it from the mains, but just for some seconds (so the PIN protection didn´t react), but I will try it for a longer time (as soon as SHMBO is finished watching TV).
You could try a reset of the TV.
With the BeoRemote One in your hands.
1. Press the little "House button". The menu button.
2. Go one step down to Setup.
3. Now press Red > Red > Go. You enter the service menu.
4. Go to Settings
5. At the bottom of this menu an option to Reset to default.
6. The TV should now have reset and shows the list of languages to choose from. At this point you turn off the TV. The speakers should retract in and up.
You might need to do the reset process twice for it to work.
I hope this works for you.
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Siggi:Hi Daniel, you moved the TV in the house with the speakers in "stay out position" ? Greetings Siggi
Champbeo:You could try a reset of the TV. With the BeoRemote One in your hands. 1. Press the little "House button". The menu button. 2. Go one step down to Setup. 3. Now press Red > Red > Go. You enter the service menu. 4. Go to Settings 5. At the bottom of this menu an option to Reset to default. 6. The TV should now have reset and shows the list of languages to choose from. At this point you turn off the TV. The speakers should retract in and up. You might need to do the reset process twice for it to work. I hope this works for you.
Michael:Sounds like either the safety pin is in so that they can not move or that the cable for the motors has somehow gotten loose so that there is no power. If you can’t hear any mechanical noise then it’s probably the latter. I almost rather enjoy it like that as it looks so boring without the speakers anyway. :)
