Hello all!
Tried to search but couldn´t find what I´m looking for.. Today I have a BV 8-32 and a old BV5-42. Very happy with both of them in relation to how I use them! :)
Thinking of buying a used BV10-40 or maybe 10-46. Are there any differences in sound quality between these two?
Image quality will be better compared to my old TV´s of course but what about sound quality/performance?Has any one experience the difference between these models BV8, BV5 and BV10? I will not use extra speakers..
I know there are different MK1 verisons of the BV10, mainly different amount of HDMI as I read..?! (I will only use ATV4K thou.)
Any thing special to look up when buying a used BV10? Should I avoid any Mk-version or Serial no regarding quality?
Is it possible by the menu system to see how many hours running time the TV has?
Any input would be appreciated!
Thanks!
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Hi!
Thanks for your input! I will consider BV11, close to where I live there´s mainly BV10 for sale thou. The BV10/11 will not be our main TV either, therefore I considered BV10 but I have read about bad panels on the BV10 unfortunately.. But thanks anyway! :)
