B&O Overture with an Extra Set of Speakers
This post has 0 Replies | 0 Followers
striker27
Posts 64
striker27 Posted: Sun, Dec 2 2012 8:26 AM
As the title states I have a B&O Overture with a set of 2500 Beolab speakers.  The system is also driving a Beolab 2000 in a den as well as a B&O passive amp in a bedroom controlled by an IR eye.  This is all connected with Masterlink.  I would like to add another set of speakers in a room nearby the Overture and Beolab 2500s.  Which would play when the 2500's  are playing and I will use the Overture to control them as well .  Can I ask what is the easiest way to do this??  Would I need another passive amp?   Could I use the connectors on the Beolab 2500's and just get another set of active speakers??  I really have no idea how to do this and I think it should be simple...
Page 1 of 1 (1 items) | RSS
