Beo 4 remote
Nivlem
Posts 1
Nivlem Posted: Wed, Apr 21 2021 12:00 PM
Hi, I'm a new member so not sure how this works but can anyone tell me where is the back button on the beo 4 remote, I have 3 different models and none of them show a back button.
Guy
Warwickshire
Posts 2,590
Guy replied on Wed, Apr 21 2021 12:06 PM
Only the latest Beo4 Navi (with the small centre mini 'joystick') has a BACK button - it replaced the EXIT button, which has more or less the same function, depending on what you are doing.
Often you would use either EXIT, the left arrow or MENU instead of 'back' - you get used to it after a while!
Page 1 of 1 (2 items) | RSS
