Turntable 3300 issue
Greets
Posts 3
Greets Posted: Fri, Dec 4 2020 11:14 PM
I have a 3300 turntable. LP records play but not the first 2 inches of the record. Anybody know what the issue is?
Thanks,
Neil
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Dec 5 2020 7:56 AM
Sounds like it thinks you'r eplaying a 7-inch record.
Record size is determined by record weight. Check if the center tap feels spring-loaded.
Greets
Posts 3
Greets replied on Sat, Dec 5 2020 6:00 PM
Martin,
The centre is spring loaded. Turntable knows an LP on the deck as cartridge arm goes to the edge of the LP.
Neil
Dillen
Posts 13,191
Dillen replied on Sat, Dec 5 2020 7:40 PM
So it actually sets down correctly at the lead-in groove of a 12" LP?
Greets
Posts 3
Greets replied on Wed, Apr 28 2021 12:36 PM
Yes it sits down at the start of the LP but no sound comes out of the speakers until about 2” into the LP. System then plays normally. Has been like this ever since I moved house.
Appreciate any advice on what it could be.
Neil
Page 1 of 1 (5 items) | RSS
