I currently use beolab 18/19 as part of a 5.1 environment with a Marantz AVR.
Marantz utilizes a very excellent sound adjustment system.
Beolab has its own room adjustment system built in.
Will this become a conflict and of course with Beolab 28 you no longer have a separate subwoofer which is used as crossover for all speakers within 5.1.
do you think this would be a problem?
should read:
The new Beolab 28 has its own room adjustment system built in.
Will this become a conflict and of course with Beolab 28 you no longer have a separate subwoofer which is used as crossover for all speakers within 5.1?
