Hello, Beofuns. Need yours advice. After a recent purchase Beolab 3 I try to connect them to Beocenter 2500. After starting playback the glass doors is open and don't close. ) When Beocenter was connected to Beolab 2500 everything was fine. Then I connect BL3 to Ouverture and and everything is fine too - I mean that the glass doors is close after a few seconds. I think that all this has something to do with the Powerlink MK 3 cable ?
Beosound 9000 + Beolab 8000, Beosound Century, Beocenter 2500 + Beolab 2500, Beosound 6, Beoplay H6, Beoplay H6 (2-го поколения), Beoplay H8, Beoplay H9, Beoplay E8
Everything works fine with BL 2500 . I think it has something to do with the cable - BL3 with Powerlink MK3 vs MK1 for BL 2500.
Have a look at this thread: https://archivedarchivedforum2.beoworld.org/forums/p/32921/268304.aspx#268304
In short, users have noticed some sort of incompatibility between BC2300 (similar to 2500) doors and the BL3 speakers. I think that there may be more threads on this issue but I can't find them.
Try moving the speakers further away from the BC2500. Or try Mk3 Powerlink cables.
You "re right , the same problem.
I used with BL3 exactly Mk 3 Powerlink Cables and think that the problem is related with ground the digital amps in BL 3 , may be BC2500 not designed for this ground ?
