RX 2 tone arm/cartridge repair
This post has 3 Replies | 3 Followers
dhemch
Nashville
Posts 1
dhemch Posted: Wed, Jan 4 2017 8:50 PM
I haven't seen this as a post/discussion, so please forgive a BeoWorld neophyte if this is a repeat conundrum....
I have a Beogram RX 2 turntable (original owner since @ 1987) that was damaged in a recent move, with the cartridge being essentially sheared off and lost (photo below) .   In trying to fix it, a few questions have come up:
1) is there a replacement piece for that part of the tone arm onto which i could then attach a new cartridge or would i have to replace the whole tone arm assembly?  curious as diagrams seem to indicate that it is a single unit, but Ive also noticed other similar B&O turntables with the same break. 2) is there a name for that particular part?  3) would a tone arm from a similar-but-different B&O turntable work as an option for replacing the entire assembly-  like from a Beogram 1800 or RX- and if so, which models are campatible?
Thanks,
Doug
ProGram
59269 Beckum, Germany
Posts 383
ProGram replied on Thu, Jan 5 2017 5:26 AM
Hi Doug,
to make it short:
1) No, you will have to replace the whole tonearm
2) So I would call that tonearm
3) That is possible, you can use the 1800, 2000 and 5000 for sure, because they are all together in one service manual
Chris
Søren Mexico
Mexico City
Posts 6,411
ProGram:
Hi Doug,
to make it short:
Chris
As Chris says, the whole tonearm, Check Ebay they come up there once in a while
Dange
Posts 2
Dange replied on Mon, May 10 2021 12:29 PM
I’m interested on how this went? I have the same issue, and have sourced a tonearm but hoping for some advice before just taking it all apart.
many Thanks
Page 1 of 1 (4 items) | RSS
