this weekend I found a Gr 2400 B&O turntable in the basement. I was told it was not used any longer because the needle was bent. The receiver is still being used and sounds great.
Does anyone know where I could find a needle that would work. it has MMC 4000 stamped on it?
Any help appreciated
thanks
Hi, have you searched the internet ?
Thanks for your response
So far I have not found anything online, Seen a couple but there expensive and I have no idea if they will work, I would hate to buy one
and then find that needle is messed up, then I really out.
I am not sure of a reliable source
Have any ideas
Thank you
Tracy
I suggest you contact Hans Henrikpickupservice@outlook.dk
He can also handle repairs.
I'll try that and see what happens
thanks again
T
