Masterlink and the BV9
This post has 1 Reply | 0 Followers
perriama
Posts 30
perriama Posted: Mon, May 10 2021 7:52 AM
Hi Beoworlders,
Have a strange issue with a mlgw that I was hoping someone might be able to answer?
When trying to configure the BV9 in mlgw, it doesn't appear to operate as intended.
After assignment, I register a single Source as DTV and try to simply switch on or off from a virtual button, with no luck. This happens also with the Source set as TV.
The assignment seems to work, switching the device off on registration, but after that, it doesn't seem to want to play ball?
The mlgw audio configuration works perfectly.
My initial thoughts were on addressing. The BV9 seems to have an ML backbone inside it, operating the beomaster5 and beosystem3. It seems that any address I give doesn't work.
Any help greatly appreciated.
perriama
Posts 30
perriama replied on Mon, May 10 2021 4:21 PM
Ok found it. Customer Service menu by MENU > Highlight OPTIONS >RED button then GO
Select Adjustments
Set to ON - Stats. to MLGW and CMDs. to MLGW
Page 1 of 1 (2 items) | RSS
