Core: was it upgraded?
BeoFrederic
Posts 276
BeoFrederic Posted: Sun, May 9 2021 2:41 AM
Was the Core upgraded to support AirPlay 2? Has it been upgraded with any new capabilities or features since it was introduced in 2017?
Curly
FL, USA
Posts 366
Curly replied on Sun, May 9 2021 12:52 PM
The Core supports AP2 but this was a software update—not a hardware change.
There was a hardware update made at some point to allow for the use of an IR eye, I believe. That’s the only hardware change implemented so far. If you do a search, you can find a thread or two about that here on the forum with more detailed info. I hope that helps!
Currently: BeoLab 17, BeoLab 18, BeoSound Core, Beosound Level, Beosound A1 2nd Gen, BeoPlay S8 Connection Hub, Halo, Essence Remote
Previously: BeoSound 1 non-GVA
BeoFrederic
Posts 276
Thanks, Curly.  It's good to see that B&O are keeping the device up-to-date, as promised at the product launch/Shape launch.  A good omen for the BL 28 and future smart speakers, perhaps.
I ask the question because I'm expecting some interesting audio announcements from Apple coming at the June developer's conference (WWDC).
avensis18
Posts 20
avensis18 replied on Wed, May 12 2021 11:24 AM
Hi, thank you for your answer I was wondering the same question too.
Page 1 of 1 (4 items) | RSS
