Beoplay A6 frequently crashing after latest software updates
This post has 3 Replies | 0 Followers
jk1002
Posts 278
jk1002 Posted: Wed, May 12 2021 7:51 PM
my Beoplay A6 started crashing pretty much nightly and I have to unplug it to get it back to normal. I think this came in with the software update 2 releases back. It was initially much worse but the current software seems to just let it happen overnight.
Is this just mine or do others have the problem too?
Cheers
JK
driehoek
Posts 45
driehoek replied on Wed, May 12 2021 10:23 PM
I use my A6 daily and I do not have this issue.
Normal audio, tuneIn and music via netlink works fine.
Chromecast stopped working unfortunately.
jk1002
Posts 278
jk1002 replied on Thu, May 13 2021 3:05 AM
I am not using chromecast but noted that after some updates I had to accept the user conditions again. If you go into the app under your content ....
Cheers
JK
Hiort
Sweden
Posts 2,895
Hiort replied on Thu, May 13 2021 10:27 AM
No such problems.
The critical events log is empty since the latest update in April. So that is a good thing.
Page 1 of 1 (4 items) | RSS
