Hi
Just bought a beosound level and the controls in the B&O app is a little different than usual. I have a question regarding the favorit buttons in the app, are they only there to set the favorits buttons on the Level or should I be able to use them as a shortcut to the radioprograms I have chosen as favorits? Nothing happens when I push the buttons in the app.
Brgds Mogens
Nothing happens when you push them in the app, but they will start when you use the left and right button on your Level when you’re playing TuneIn.
