I am a bit confused about the Transmitter 1.
I read that it can do 7.1 sound, and it's made for the 18, 19 etc
So can I connect it the TM1 to a Sony TV via optical, and then connect 2 BL18 (without PL cables) and 2 other speakers with Receiver 1's?
Im guessing if it can talk to Receiver 1's then it should be able to talk to the 18s no problem.
Please help!
The opening paragraph of this tells me it is, but it would be good to hear from fellow BW people
https://beoprime.com/media/pdf/6c/88/d1/Guide-BeoLab-Transmitter-1-25870e66de005f.pdf
Is it hard to set up?
Does it work well?
Or, is it that it's wireless but it doesn't do the decoding, so you would still need an AV receiver and the BLTransmitter? Is that it?
Thanks in advance
Using the optical in will only provide you 2.0/2.1 channels (aka stereo).
thanks guys - good pick up MM
mbolo can your setup do 5.1?
M
You would have to set the output (over optical) to stereo/2 channel - otherweise you won’t have any sound at all.
Maybe reading the guide of the Transmitter could shed some light on your options with the Sony tv:
One possible scenario could be to connect the Core to the Transmitter/PL and the tv to the Transmitter/optical.
And maybe the additional ir-receiver would work with your Sony in order to control the sound.
Just some thoughts - since I am not able to test these things.
Yes, in order to have 5.1 (more than 2 channel) sound you would need a receiver with preouts of these channels.....or a BV 😉
Thanks MM, i did read that and to me it wasn't very clear if you can have all of the PL occupied and it still outputs to WISA.
And yes, one scenario could be TV to the Transmitter/optical, but that would only stereo and agree that if i went down the path of the Transmitter, then i would need an AV receiver if i want to do WISA to BL's.
Thanks Paul, I already have 2 BV. This is for a different television. And being that there will be less BV going forward, and even B&O using third party screens (LG) then this is a likely scenario for a lot of other people.
So in conclusion. The Transmitter 1 is actually wireless.
Aussie Michael:So in conclusion. The Transmitter 1 is actually wireless.
I’d say, yes and no!
If the question was about the connection/s to the (WiSA compatible) BL’s, then definitely yes.
Everything else is not wireless.
Mbolo is your setup that you described stereo or 5.1 ? Im guessing stereo, but just wanted to clarify, thanks in advance.
Aussie Michael:Mbolo is your setup that you described stereo or 5.1 ? Im guessing stereo, but just wanted to clarify, thanks in advance.
Aussie Michael: Mbolo is your setup that you described stereo or 5.1 ? Im guessing stereo, but just wanted to clarify, thanks in advance.
<I have tried to answer several times through the app, unsuccessfully, sorry if it comes later>
My setup is stereo only as my TR1 is configured as a WISA Switch (see page 15 of the doc if I remember well)
That said I doubt that (1) my Samsung TV would process and propagate x.1 sound through the optical out, (2) that the Core would process and propagate a x.1 signal received on its optical in to appropriate wireless speakers paired with the TR1 ... but someone may have an answer to this.
And to conclude, I'm very satisfied with my 2.1 setup with 4 speakers in stereo (two fronts, two rears) and a sub. x.1 sources are rare or not existing in my environment.
Thank you for your response :-)
Hi mbolo01,
Can TR1 work as a WISA Switch but with the signal coming from its Optical input ?
I'm thinking of doing a similar setup with a stereo 4.1.
The thing is, there's a double Digital->Analog conversion happening because the Core is connected to TR1 with PowerLink:
- 1st conversion happens in the Core when it sending via PowerLink
- 2nd conversion happens at the speakers
If the Core was to connect to TR1 with Optical, the signal will stay digital until reaching the speakers.
pig30n:Can TR1 work as a WISA Switch but with the signal coming from its Optical input ?
