Volume BeoSound Level
marcengels
Posts 44
marcengels Posted: Mon, May 24 2021 11:04 AM
Hi guys, when I turn up the volume all goes well to about 80%. When I go to let's say 90% the volume goes up a little but then goes back to approximately 80%. Same as when I try to go to 100%. But when I then go back to let's say 50% the volume goes to a point where you hear almost nothing! But then slowly the volume increases automatically (to 50%)
Maximum volume is set to 100%in the app.
Anyone else having this "problem"?
Duels
England
Posts 2,553
Duels replied on Mon, May 24 2021 12:15 PM
It sounds like the Level’s in-built thermal protection is kicking in to protect the speaker from excessive sound levels.
If you regularly listen at 80-90% volume you may need to consider a more powerful speaker.
marcengels
Posts 44
marcengels replied on Mon, May 24 2021 12:34 PM
Don't get me wrong, not listening at those levels. Was just testing it.
Duels
England
Posts 2,553
Duels replied on Mon, May 24 2021 12:39 PM
Ah ok.
I believe it is behaving correctly.
marcengels
Posts 44
marcengels replied on Mon, May 24 2021 12:50 PM
Thanks man.
Page 1 of 1 (5 items) | RSS
