I have an SM80.2, the slightly more "airy" model of furniture that belongs with the Beomaster 8000 with friends.
It lacks the plates that act as walls in the disc tray and also the plastic plugs that will hold these walls. The plates are not a big deal, I can cut and paint these if I had the right measurements. I can also make the plastic plugs with a 3D printer.
My question is if anyone can assist me with these measurements: partly height, width and thickness of the plates, partly so many dimensions and preferably photograph (s) of the plastic plugs.
http://tinyurl.com/qj9cjsf
Is it a palisander or a white sc80.2 ?
I have some plastik plugs for a white,and i could give you the size for the metal plates.
Send me an pm.
Kind regards.
Henrik.
https://archivedforum2.beoworld.org/forums/t/11223.aspx
Thanks to square4 this is now sorted out.
