Beovox S45-2 (3 way) preventive care.
This post has 4 Replies | 0 Followers
matador43
Posts 1,373
matador43 Posted: Tue, Jun 22 2021 6:39 PM
Hi Guys,
I (don't ask me why) have bought a pair of S45-2 to encourage me to recap my Beomaster 1001, even if I suspect both may not be a good fit. Anyway.
I've read a lot about magnet seizure and I wonder if something can be done before it happens, like superglueing it while it is still in place.
Despite finding them sounding very well, I also discovered one tweeter was silent.
Is it something that ca be repaired or is it just a matter of changing it ?
I know I should change the caps in the filters but right now it dont sounds like an emergency and as said, I'm still gathering my courage for the 1001.
Thanks for any advice.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Jun 22 2021 9:27 PM
ALWAYS glue the woofer magnets.
Replace capacitors, check for burned resistors, and see if the tweeter is still silent.
If still silent, replace it.
matador43
Posts 1,373
matador43 replied on Wed, Jun 23 2021 10:05 AM
Thanks Martin,
Glueing the woofer is putting a cord of glue (2 components epoxy?) at the junction between the bowl and the magnet right?
Like Rubson between the wall and the bathtub?
The tweeter is definitely burned. I'll PM you about replacement.
Dillen
Posts 13,191
Dillen replied on Wed, Jun 23 2021 10:49 AM
Yes, a bead of glue between the magnet and the basket, and between the magnet and the end cap:
matador43
Posts 1,373
matador43 replied on Wed, Jun 23 2021 3:58 PM
Thank you. That's perfectly clear now.
Page 1 of 1 (5 items) | RSS
