New member here. I've been struggling for a couple of days with issues on setting up my BeoSound Stage with a new 2021 model LG C1 series TV.
I've worked my way through the setup with some great help from the B&O help desk folks. I'm an old guy that barely knows how Apple Airplay and Google Home work on a wireless network.
The Beosound Stage is now is now up and running through the eARC HDMI connection on the TV with one problem. I can't control the volume with the LG TV remote control. I've tried resets, unplugging/plugging back in, etc. I've been through ever item in the LG settings and can't find a problem. I contacted the LG help-desk, and the technician had never heard of Bang & Olufsen and said he would get back to me in a half hour. That didn't happen. I finally hit my frustration point and ordered a Beoremote One today, but I hate being dumb and not being able to figure out my problem.
Thanks to anyone that has a suggestion.
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
I did not have the ethernet cable connection. I did this, and also downloaded the B&O app from the LG store on to the TV. I'm not sure which one was the solution, but I can now control the volume from the TV remote. I will say that I didn't have to do this on my 2019 LG C9 series TV. But with a new 2021 LG C1 series TV, this needed to be done. Interesting.
Thank you for your help.
Buckturgidson: I did not have the ethernet cable connection. I did this, and also downloaded the B&O app from the LG store on to the TV. I'm not sure which one was the solution, but I can now control the volume from the TV remote. I will say that I didn't have to do this on my 2019 LG C9 series TV. But with a new 2021 LG C1 series TV, this needed to be done. Interesting. Thank you for your help.
In your initial post you wrote: ‘I can't control the volume with the LG TV remote control.’
Was that you intention?
If yes - I am curious - why don’t you want to use the Beoremote One?
