Hope someone can help. I have just purchased a beogram4000c. When I connect it to my Ouverture through the Aux socket I get a very loud hum, especially when the stylus contacts the vinyl. I have a One Remote RIAA-II connected between the Ouverture and the Beogram.I have also tried connecting the Beogram to a Marshall amp/speaker with the same result. In both cases all the units were powered from the same mains ring.Anyone have any ideas.
Congrats on the 4000c. I'm eagerly awaiting mine. The 4000c has a built-in phono preamp, so you would not need to have another phono preamp connected in between, and although I've never tried it I would assume having a double preamp connection would likely cause a hum or distortion from too much gain. Have you tried connecting the 4000c directly to the Ouverture without the external preamp?
--Beovision Harmony 77, Beovision Harmony 65 x2, Beovision Contour 48, LG GX 65/Beosound Stage/STB StandBeolab 50s, Beolab 28s, Beolab 18s x3, Beolab 19, Beoplay A9, Beosound Edge, Beosound 2 x2, Beosound 1 x2, Beosound Level x2, Beosound Core x2, Beoplay M3, Beosound 9000, Beogram TX2, Beogram 6500 White Edition, 4000c (on order), Beoremote One x8, Beoremote Halo x3, BLC NL/MLBeoplay H95 x3, Beoplay EQ x2, Beoplay E8, Beoplay E8 Sport, Beosound A1 x2
Hi Josh thanks for getting back so quickly. Originally I tried it without the pre-amp and it had the hum. Apparently it requires the pre-amp to work with the Ouverture, so bought one - still the same issue only could now hear the vinyl with hum. Thought it might be a ground loop issue so moved everything on to the same mains ring - still the issue. Also tried it with a ground loop isolator to no avail.
Hi Josh, should have been a Beogram 4004 not the 4000c. not sure what the differences are. I take it you have bought a new one - nice
murraym: Beogram 4004 not the 4000c. not sure what the differences are
RIAA / no RIAA.Different grounding requirements accordingly.Oh, - and around 9000 euros on the price tag.
But a Beogram 4004 is still a very nice deck if restored properly.
