AUX Connection to Beosound 4
Andrewfalk
Posts 3
Andrewfalk Posted: Sun, Aug 8 2021 5:45 PM
Would it be possible to get a successful connection from the headset socket on my old beomaster amplifier to the AUX sockets on the Beosound 4 and, if so, what dimensions are required
lawrencejmcook
Posts 742
Andrewfalk:
It would be better to get the sound from the Tape (out) connection on your old Beomaster. This would allow you to control volume with the Beosound 4’s remote (or from the B&O app if you have a Beolink NL/ML converter).
Steve at Sounds Heavenly should be able to provide the correct cable.
Page 1 of 1 (2 items) | RSS
