Hello members of the BeoWorld forum. Can someone give me a description of the sound between the S45 and the S45-2's? Im trying to decide which one to buy. I really love the look of the S45 with the 2 panel design. However, sound quality beats all. Opinions on the 2 models?
-Noah M.
RL 60.2, Beogram 5500, Beomaster 5500, Master Control Pannel 5500, Audio Terminal Remote, H9i, Beovox s45.2, Beosystem 2500 , Beogram 1602, Beolink 1000 remote, Beosound 2000, Beoremote 4.
Looking for: Beocenter 8000
Perhaps part of your answer can be found here:
S 45 vs S 45-2 - any difference in sound quality? - (beoworld.org)
Beovox S80 or S80.2 would probably be the two-part baffle model that comes closest to the S45 (6302) and S45-2 (6312), both soundwise and model range-wise. All of the two-part baffle models will need woofer refoaming by now.Not impossible, but not a job for everyone.
Thanks for the link! Im probably going to go for the 2 grill S-45 because of the design after hearing they sound very similar to they S-45-2. My uncle has the S-45's and they sound decent.
