Spotify Connect on BeoSound Stage or Edge?
pig30n
Posts 35
pig30n Posted: Wed, Aug 11 2021 7:43 PM
Greetings!
I would like to know if either BeoSound Stage or Edge have integrated Spotify Connect.
I can’t find that in the specs anywhere. Did they missed adding Spotify to the specs ?
Currently, I’m using a Core+BL18+BL19 in the living room either streaming via Spotify or as TV’s speakers.
Also, not really important but, will the Stage or Edge be able to join a Multiroom playback together with the Core in the living room?
Thanks.
pentalex
Posts 39
pentalex replied on Thu, Aug 12 2021 3:56 PM
The stage supports Spotify by chrome cast/ Google home.
You cant listen to Spotify on Core and Stage together. You have to choose.
if I got it on the Stage and go to the Core, it tells on the Stage it stopped playing because Spotify is now used on another devise.
So you can use Spotify on both devices, but not at the same time or by multiroom.
Page 1 of 1 (2 items) | RSS
