Hello,
I have bought a used Beovison 12-65 2nd generation that was stored for some years - it was working as the owner said.
Well, I tried to start/turn on the TV, but nothing happend. I use a Beosystem 3 that might not be the best solution, but the TV should work with this device.
A first and quick search finding the mistake showed, that power or current reaches all parts. But: there is a part in which the main power cable is set on. From this part there are three other cable reaching out to different electric devices. Two main cable are showing current, the third tiny cable - leading towards the basis where the plugs are putted in - has no current.
My question ist: does someone has an advice or an idea how I can reactivate the Beovision 12? Or does someone has some spare parts?
Kindly
Dominic
