Hi
I have the opportunity to buy a beolab 2 for virtually nothing.
Only thing is one cover on a speaker is missing....is it easy for one of those to come off?
Can I use it as is till I find a replacement?
I recently got the Beolab 2 to give a little more punch to my set up with the classic Beosound 9000 and a pair of Beolab 8000. At lower volumes I love this combination! My issue is at higher volumes: There seems to be some leakages around the connection panel at the back. The seal for the speaker itself and the slaves on the sides seems good, so I'm pretty sure it's only on the back. IndigoCard What this does is that it makes a noise similar to a badly ported sub. A loud flapping noise if you will. The back panel looks to maybe be a bit out of place, where the lower part is positioned a bit deeper than the top part ??
