Hello
I have bought a Beosound Edge and are planning to mount it on the wall using the wall bracket included with the speaker. With this bracket the speaker will be hanging 90 degrees on the wall with both sides free.
I have one consern and that is how this mounting will affect the neighbor living on the other side of the wall. Will the bass travel through the wall more when mounting it this way instead of having it standing on the floor?
Thank you in advance for your thought on this.
Regards
Jarle
