Hello,
I have a Beosound Ouverture and Beolab 1 speakers. I use the AUX output to use my loudspeakers for the TV, streaming, sending my iTunes music from my iMac, etc. Works great.
The problem is, I have no remote way to turn the Ouverture on and off other than using the Beo4 remote control. I tried a universal remote control hub, but sadly discovered it is unable to learn the Beo4 IR codes (and read somewhere on this forum about how different B&O is concerning the RC). I contacted B&O support, and they were less than helpful.
So is there any way to easily do this with commercially available products using an iOS app? If not, is there a DIY way to do this? Could MasterLink be used to do this in some way? Etc.
Thanks for your help.
Tony
You can use a blc nl/ml connected via master link to ouverture. The blc needs a wired connection to your network though.
Then it's just using the b&o app.
How about this: https://www.ricardo.ch/fr/a/telecommande-bang-olufsen-par-smartphone-975172496/
Guy: How about this: https://www.ricardo.ch/fr/a/telecommande-bang-olufsen-par-smartphone-975172496/
That's the guy who makes the Beo4 to remote plugs converter! A trustful seller.
soloAudio:I tried a universal remote control hub, but sadly discovered it is unable to learn the Beo4 IR codes
After checking around, I decided to do this myself using a very inexpensive ESP32. With a Vishay TSAL4400 emitter, and the RMT peripheral driver and a WiFi server. I can now successfully control my Beosound Ouverture using power on and off, and raise the volume up and down, from my iPhone.
Thanks for everyone's help.
Seems interesting to me - I'm in need for a controller that can turn on a Beolab 3500 without using the Beo4 - would it be possible for you to elaborate further to how you made the setup and the code needed for the ESP?
Hi klbu,
Yes, I can provide details on how I did this. I'll need some time to gather this up and will post.
Thanks for your answer - that would be really great if you can provide me with the details.
/Klaus
Hardware
soloAudio:Here are the details of how I solved this. I hope this is helpful for you.
Hi Tony,
Please confirm I've understood you well:
What you did is an IR blaster sending Beo4 streams, running a little web server you can control over network?If it is so, I got a couple of questions for you:
- Could you add more controls. Like source selection, CD/track selection, Channel Selection etc… Would this be easy or complicated.- From where do you take (lear) the IR controls? (related to the previous question).- Could this work with non B&O equipment? And mixed brand (like Samsung TV with B&O sound system)?
I feel like they could be very funny and useful things to do with this, dont know precisely what just now, but it opens possibilities.
Thank you.
[Tony]
Yes, that is correct (as originally stated when this thread was started). It is just a WiFi controlled Beo4 emulator.
Thank you Tony for your comprehensive answer,
It sounds like beyond my reach right now (specifically the part with mixed IR protocols) and at the same time very exciting. But anyway the door is open and i'll keep that somewhere in a corner of my mind for later.
Thanks again for your work and the knowledge you shared.
thanx for your great work! Is there a way to send hex or raw code ?
I got this code (Bemooster 7000)
Radio: 1908FF000001001605003502DF00350F10003505EA003508F800350C05000001000202020202020 20302000202020202030404 CD: 1908FF000001001605003602DE00360F0F003605E9003608F600360C03000001000202020202020 20302000203000203000404 Phono: 19080082000500130C00320061004C008E004C005E0072002600260026004C01100026008800320 1C700370026003200C1009C00440076390D00010201030402050504060703080801090A0B AUX: 190800820005000E0B005C003D00310058005C00F3005C009300310098004F0026005C006100260 0A800310076002600260031390E000102030405050607010809050A Laut: 1908FF000001005506003002DD00300F11003005E9003008F700300C03003021990000010002020 2020202020300030200020202020405000001000202020202020203000302000202020204000001 000202020202020203000302000202020204000001000202020202020203000302000202020202 Leise: 1908FF000001005506003002DE00300F11003005E9003008F700300C03003021990000010002020 2020202020300030200020300020405000001000202020202020203000302000203000204000001 000202020202020203000302000203000204000001000202020202020203000302000203000202 Mute: 1908FF000001001605003502DF00350F10003505EA003508F800350C05000001000202020202020 20300020202030200030404 Input Phono: 190800820005001A0E00350046003500CD00260053006B003D00350027002600270026003B00260 0F1006B006B006B00A40035005C006BFFFB0035007A003539080001000002030400040506070803 040904080A0B0C030105030D Input AUX: 19080082000500130E00320065004B009C004B0062007000260026002600D40026009600E000320 09500570026007200D10032004A003D00260072009F003239060001020103040005060707080109 0A0B0C030D Input V AUX: 19080082000500110B002F004F002F00D4002F00760045008900570026002F002E0045005B00260 05600A701E200A700B4002F3902000102030000040401050605070108090A Power OFF: 1908FF000001001605003402DE00340F11003405EB003408F800340C05000001000202020202020 20300020202030200020404 Input Tape: 1908FF000001001605003502DE00350F10003505EA003508F700350C04000001000202020202020 20302000203000202030404 Input Tape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
20300020202030002030404
