Recently my beo center 7007 has stopped working. When it turns on it only shows the 0 15 and 3 lights and apart from that the buttons or remote do not work. I am wondering if anybody has encountered a similar issue.
Thanks.
Check the three large filter capacitors.They are known to fail, causing too much ripple on the supply rails.
