I have a Beovision 12 NG with NL connected to nework via WIFI. and a Beosound 9000 with ML.
My question is, can a beolink converter from NL/ML work with my BV-12 connected to internet via WIFI. Because i am not able to connect BV-12 via cable to the Beolink converter.
Because i would like to play music from BS9000 to the speakers of my tv.
Thanks in advance.
The NL/ML Converter doesn't need to be connected by cable directly to the Beovision 12. The NL/ML Converter just needs to be connected to your network via cat7 cable. The converter does not have wifi. However, the Beovision 12 can connect to that network via wifi and communicate with the converter.
Perfect, that was exactly what I was hoping to hear.
Does it need to be Cat7? isn't it just for network connectivity?
