Hello to all,
I was wondering if any of you has tried to use a beosound level as surround speakers, or at least any other bang&olufsen speaker with only a line-in connection. In case there is someone would you be kind enough to write your experience?
Thank you
Anastasios
It was asked before here: https://archivedforum2.beoworld.org/forums/p/49512/348642.aspx#348642
Thank you guy I have already seen this but I was wondering if someone has when the extra mile and connected the level (or any other B&O) speaker via its line-in connection to a surround capable B&O TV.
Tassos: Thank you guy I have already seen this but I was wondering if someone has when the extra mile and connected the level (or any other B&O) speaker via its line-in connection to a surround capable B&O TV.
I can’t say - I did not try.
However, I assume the the sound processing in the Level will cause far too much delay on the signal.
