I have replaced the jvc projector with the above sony, but for some reason, it wont display the picture, reading the manual for tbe projector, it suggests to use a high speed hdmi cable, the output on the beosystem 3 is dvi, if i use dvi to hdmi adaptor and the new cable. This should reaolve the issue, has anyone run into this issue?
