Hi , we have a Beovision7 that was working perfectly fine one day then just stopped the next. It appears that there is no power going to the television. Can anyone tell me if it’s possible to fix or what the issue could be. We are thinking that maybe there was a power surge ? Can anyone shed any light on the situation ? thanks for any advice
I think there's a worldwide Beovision 7 situation! Mine's just done the very same thing! Switched itself off and now no power to it at all. No standby light, no sign of life. I'm thinking power supply, but the potential repair cost might be frightening
You need to check the standby inverter.
