Hi - I have a cable to connect a BeoSound 3500 to my TV.....the only problem is that I don't have any remote control. I have heard that Universal Remotes do not work on the 3500. Is there any work around without using the Beo4 or Beolink 1000 remotes ?
Hi
You mean BeoLab 3500 link speaker connected to Non-B&O TV ?
Connected via special minijack to Powerlink/MCL cable ?
You'll need a B&O remote to turn it on !
Regards
Ravsted
ok - thank you for that confirmation.
