Volume control fault on Beomaster 6000
michaelmaurice
Posts 30
Silver Member
michaelmaurice Posted: Mon, Nov 15 2021 2:00 PM
The motor which controls the volume control has failed.  I tried to dismantle it to see if I could lubricated but the little brass cog on the end of the motor broke up when i tried to remove it.
I was considering replacing the motor with a new motor with gearbox, has anyone else done this?
One other thing, how do you get the panel out that holds the motor?  It seems that there is a hidden screw under the front panel.
Page 1 of 1 (1 items) | RSS
DigiCert Secured Site Seal
