Store Stand position for BeoVision MX 7000-BE04 Type: 78/94 EDT SW 2.0
Sebastian Bergström
Sweden
Posts 2
Silver Member
Sebastian Bergström RTFM [@Lee5] Posted: Sat, Nov 27 2021 1:17 AM
Hi! Any help is deeply appreciated. I cannot for the life of me figure out how to store the stand position.
According to the manual I need to:
  1. Press LIST in order to find V. SETUP
  2. Press GO
  3. Press LIST to show PICTURE
  4. Press GO
  5. Press LIST to show STORE
  6. Press GO twice to store the new position
I cannot in anyway get up either V. SETUP, PICTURE or STORE on the remote.
When I try to use the SETUP meny I have very few options and none of them has anything to do with the stand.
Thanks!
Best regards,
Sebastian from Sweden
Johan
Bolsward, NL
Posts 450
Johan replied on Sat, Nov 27 2021 8:20 AM
Hello Sebastian, and welcome!
The LIST button on the remote provides extra functions... ...once you added them! :-)
Here you can find the manual including how to do so, and a list of all those functions: https://support.bang-olufsen.com/hc/en-us/articles/360041836251-Beo4-without-navigation-button-
There are many Beo4 types, but I trust you can find what you need.
Hope this helps!
Johan
Sebastian Bergström
Sweden
Posts 2
Silver Member
Thank you Johan! Got it to work now thanks to you Smile
Page 1 of 1 (3 items) | RSS
