Beo4 remote and the Core
This post has 14 Replies | 2 Followers
Techno
Posts 11
Techno Posted: Tue, Aug 18 2020 7:44 AM
Considering a B&O Core. Have a Beosound 4 which I operate with a Beo 4 remote control.  Does anyone know if the Beo 4 remote will operate the Core. Would be nice and simple to control both sound sources with one controller. (I know the Core can be operated by the B&O app.). Many thanks.
Hiort
Sweden
Posts 2,895
Hiort replied on Tue, Aug 18 2020 8:01 AM
There is a version of Core where you can connect the B&O IR-Eye. I know that you then can control it with the IR version of BeoremoteOne and would assume it works with Beo4 as well.
OlivierC
Posts 128
OlivierC replied on Tue, Aug 18 2020 9:02 AM
Hi Techno,
Hiort suggestion is correct, so make sure you’ll get the latest version of the Core, Mk 2, the one with the IR eye, Type Nr. 3051.
Hereunder the link of one of the few threads where you can get the information.
Regards.
Olivier
https://archivedforum2.beoworld.org/forums/p/33455/251898.aspx#251898
Peter Pan:
@ elephant
NOTE! New Mark II of BeoSound Core: BeoSound Core with IR Type No. 3051. BeoSound Core version without IR type no. 2797. (should now be sold out in DK).
lawrencejmcook
Posts 742
Hiort is correct. The Core Type No. 3051 can receive IR commands via (I think) the DPL socket. You will need to add the latest version of the BeoLink IR eye and cable with the Join button and RJ45 plug.
Lawrence
Techno
Posts 11
Techno replied on Tue, Aug 18 2020 5:10 PM
Encouraging. Many thanks.
Techno
Posts 11
Techno replied on Tue, Aug 18 2020 5:13 PM
Getting better. Knowledge base building. Cheers.
Techno
Posts 11
Techno replied on Tue, Aug 18 2020 5:17 PM
Thanks Lawrence and PeterPan.  The detailed info on version number and the link more than I expected.
Thanks Beo world forum.
Sorted.
lawrencejmcook
Posts 742
Glad you got where you wanted to be. 👍
L
chucky
Posts 331
chucky replied on Tue, Aug 18 2020 8:53 PM
Old link eye works as well. You can only send command through IR but not push to join or set volume on the eye it self.
Mailer
Posts 12
Mailer replied on Wed, Oct 13 2021 8:31 PM
which IR receivers work with the Core MK2
Cu Mailer
chucky
Posts 331
chucky replied on Wed, Oct 13 2021 9:02 PM
Actually ir recevers only work on on the mkll
Both versions however the old only receives you cannot press
Mailer
Posts 12
Mailer replied on Wed, Oct 13 2021 10:08 PM
Ich havethe 1636 Receiver with Timer, Play and the up-down Button. This Model doesent Work. do I still have to make settings on the core? The model with the joyn button works well. There is still a model without a button, maybe this model works?
Mailer
Posts 12
chucky
Posts 331
chucky replied on Sat, Nov 27 2021 5:20 PM
If you look somewhere on the Forum maybe MM knows from which number it is a MKII.
If you use an IR you might have to put it in option 1-2 or 6.
I am 100% sure that both ir models so join and the old work. But with the old you need to use the remote. Eg a BEO 4 or BEO 1 in ir mode.
Millemissen
Flensborg, Denmark
Posts 14,680
chucky:
Copy/paste from another theead here:
Core Mk II has Type No. 3051 (look at the bottom of the Core (or via app / product configuration webpage)).
Page 1 of 1 (15 items) | RSS
