Why no auto detection using WPA?
seethroughyou
UK
Posts 999
seethroughyou Posted: Sun, Dec 12 2021 8:29 AM
Have a Moment connected using wireless powerlink but when I press play on my CD or my record player, I have to go into the BeoApp. Is there a way to detect the input automatically without messing about with tablets and mobile devices?
Why has it been designed to not have auto detection on WISA?
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
seethroughyou
UK
Posts 999
I’ve disconnected wireless powerlink and connected using a powerlink cable but the left channel plays through right and right plays in the left. No apparent solution.
Millemissen
Flensborg, Denmark
Posts 14,680
That is odd - because that should be the solution (or workaround, if you will).
At some point the decision to treat the WPL differently was made - don’t know why.
Anyway, generally it always will be better to use a cabled connnection….especially with these speakers.
Hope you get it fixed.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Dec 12 2021 10:10 AM
seethroughyou:
the switches right/left are set correct?
seethroughyou
UK
Posts 999
There is no left or right switch.
seethroughyou
UK
Posts 999
Thank you dude. I will give this a try.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Dec 12 2021 6:24 PM
seethroughyou:
But there is one which decide which speaker is left and right: a software switch (is still a switch).
seethroughyou
UK
Posts 999
Glad to report the channels can be swapped. You have to go deep into the Beolab 90 app. Thank you to you all and to Geoff who sent an email late last night. Geoff Martin is force of nature and the jewel in B&O’s crown. Long live King Geoff.!!!
Page 1 of 1 (9 items) | RSS
