Dear beolovers,
My BS 9000 MK I has started to do strabge things. After 30 min. of listening Radio or CD, the system turns off completly, no standby red light.
When I disconnect the system from the socket and after 15 min. the system comes to live again and work for another 30 mins.
As the system works for a while I understand that a condenser or TR are partially OK and when the BS gets warmer a bad component is sending the signal to protect the system (?)
Can anyone of you give me indications where start to look for?
Thank you very much in advance
