strange thing's happening here - my setup's Beogram 5500 connected to BeoMaster 5500. This duo is linked thru TAPE2 AUX--AUX to Beosound 9000. Beosound 9000 plays thru BeoLab8000.
This setup works perfectly from time to time only.
What I discovered was that if I disconnect BeoMaster from AC for some time (hours probably) then it plays perfectly after plugging it back in mains. On the other hand if I want to play the vinyl and just turn on BeoMaster (not disconnecting/reconnecting exercise) then it's just silent.
Would any of you have any idea what might be the issue with BeoMaster and on what I should focus for potential repair ?
It might help by identifying the issue that the BeoMaster emits also quite a lot of humming sound (even during stand by mode)
Cheers
Marek
