In the available files on the website I cannot find the mechanical built up off the CD player. I am presently working on a CD3300 and I have a mechanical issue.
The small CD lifter plate does not come up when the door is opening. If I look at the built up I can see the small plate where it seems that a connecting part between the large metal bracket that moves up and down and the small plastic plate that carries the CD . It looks to me there is something missing between the mentioned 2 parts. Does anybody have a picture of this missing mechanism . Or the mechanical pages of the service manuals.
Thanks in advance
Fred
I found what I needed with the help of a donor cassette deck, so this is solved.
