BeoSound Edge
This post has 6 Replies | 0 Followers
benoit
France
Posts 646
benoit Posted: Thu, Dec 23 2021 9:40 PM
Hello, I'm the proud new owner of a BS Edge.
I have some questions regarding the bass port. I decided to observe it as I can hear a 'mechanical noise' when I switch the Edge on or when increasing the sound level...
Is it normal to hear it opening or closing (light 'bzzzzz noise')?
When I start the Edge the bass port closes. I noticed that its movement is more slow when 'waking up from standby' (and the noise is slightly different as well) than when it normally opens - closes while music is playing. When getting in standby, it opens again and  the movement is more slow as well. Is this the normal behavior?
Thank you for your help.
wanc1
Posts 29
wanc1 replied on Thu, Dec 23 2021 11:18 PM
Yes, what you've described above is exactly the same as my beosound edge. So it should be normal.
wanc1
Posts 29
wanc1
Posts 29
wanc1
Posts 29
benoit
France
Posts 646
benoit replied on Thu, Dec 23 2021 11:49 PM
Thank you. Now I'm reassured.
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, Dec 24 2021 8:30 AM
You have to be patient when you send a post here, just click once and wait…
Jacques
Page 1 of 1 (7 items) | RSS
