PUC List
Pestria
Posts 58
Pestria Posted: Sun, Dec 30 2012 2:06 PM
I have a Beovison 8-40 purchased new from an official B&O store in the UK about 3 years ago.
The tv currently controls a sky box and apple tv.  I want to add a DVD player and possibly some sort of alternative to the apple tv.  However I noticed that there are only the two controllers for above devices installed.
I have a few questions which I'd appreciate help on.
1. Is it normal to only have a couple of controllers installed from the dealer?
2. Can I add additional,controllers myself using a USB or similar.
3. I'm probably going to put the mark 1 atv on a mark 1 beovision 7 - again I'll need to add controllers - is it the same process?
Ap
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
Except for the future TV's starting with the Beovision 11, the PUC can only be updated by the dealer using a software Service Tool.
When you buy a Beovision there are a few "Standard" B&O entries in the PUC only and normally the dealer would ask you what other external STB's etc you wanted to control and they would normally load those from the B&O library. Clearly in your case this did not happen.
You cannot add PUC entries yourself via the USB
The dealer would need to add the PUC entries to the Beovision 7
Regards Keith....
Page 1 of 1 (2 items) | RSS
