Hi I purchased a beovision avant 32 dvd without remote. The man I bought it from gave me the pin but I have know idea how you can type the pin in manually can anyone please advise
Thanks john
…with the remote.
Some mobile phones/tablets have an IR sender and remote control apps. You could try that. I had limited success with a Sony Tablet and my BeoCenter 1. It would work but was hit and miss.You might just be able to put the PIN in.
Stoobie
