BeoCenter 9000 with 4 Speakers
SiliconTi
Posts 8
SiliconTi Posted: Tue, Jan 11 2022 8:30 PM
Hi All,
I have a client with a Beocenter 9000 that wants to connect 4 passive speakers to it. I have the correct 2-pin DIN speaker connections, Speakers two works, but Speakers one does not work. Any thoughts why speaker one doesn't work?
Thanks!
Guy
Warwickshire
Posts 2,590
Guy replied on Tue, Jan 11 2022 9:08 PM
Quite possibly a mute relay fault as this only affects spkr 1.  Try cycling mute on/off several times, but you may find that you just have to replace the relay. Search ‘mute relay’ on the forum for more info.
SiliconTi
Posts 8
SiliconTi replied on Wed, Jan 12 2022 1:48 PM
Ahh yes, I should have thought of that. It has been a long time since I have worked with an older unit. Thanks!
Page 1 of 1 (3 items) | RSS
