Hello. Interested in Beoplay E8 3 rd gen one bud is master and second slave or both buds master? In my Beoplay app, the charge level of the right bud after use shows less than that of the left( L90% R70 %). Before use after charging, the charge level is the same ( 100 %).
Beosound 9000 + Beolab 8000, Beosound Century, Beocenter 2500 + Beolab 2500, Beosound 6, Beoplay H6, Beoplay H6 (2-го поколения), Beoplay H8, Beoplay H9, Beoplay E8
Dear Amigo799,Beoplay E8 3rd Gen has a master bud (Right) and a slave bud (Left).Since I have been using this product just for 1 month, I haven't experienced this issue.How do you check the battery level for each of the bud?
Best Regards, Mit freundlichen Grüßen, 감사합니다Antonius Robin Iriawan, 로빈 올림
Beosound 35, Beoplay E8 3rd Gen, and Beoplay Earset 3i.
No longer in use: Beoplay H5
I believe it is a master / slave arrangement. That's one of the difference with the EQ. You can use either one by itself. With the e8, you can only use the right by itself.
